BX-25 hydraulic fluid use.
   / BX-25 hydraulic fluid use.
Yea, I guess if I keep on doing what I'm doing, I'll keep on getting what I'm getting. I wonder, is there some kind of dye to put in to help see where it comes out? That stuff is kind of clear and with old eyes, well you know the drill.
   / BX-25 hydraulic fluid use. #12
Yes, there is a florescent dye that you can add to the hyd and use a black light to see where the leak is.
You can get it at NAPA. Can be used in many different oils/fluids.
Just add the dye and run the hyd system, and shine the black light over all hoses, fittings, cyl, etc.
Next stop NAPA. (Tomorrow, actually.)
I'll post how it works.
Thanks -
   / BX-25 hydraulic fluid use. #14
Post some pictures/video of the leak if you find it.
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
