BX-25 starts after jiggling the HST lever
   / BX-25 starts after jiggling the HST lever #1
memmons
seattle, wa
BX25D
Hi All,
My Bx-25 is only starting sporadically and only after I jiggle the HST lever. Initially it happened infrequently now it is every time and getting worse. Is there a safety switch on the HST lever that could be causing the issue. I looked at an online parts manual but couldn't find switch.
Appreciate any advice
Thanks
Marc
   / BX-25 starts after jiggling the HST lever #2
Yes. The HST pedal must be at neutral on all Kubotas to start the engine. Something must be out of adjustment in the pedal mechanism, but I don't know that model.
   / BX-25 starts after jiggling the HST lever #3
Yes. The HST pedal must be at neutral on all Kubotas to start the engine. Something must be out of adjustment in the pedal mechanism, but I don't know that model.n
Try greasing the HST pedal.
I think it's under the floormat.
Common problem.
   / BX-25 starts after jiggling the HST lever #4
Hi All,
Thanks
Marc
What is the "HST lever" ?
Do you mean the directional pedal, or maybe the range selector?
MY BX doesn't seem to have a HST directional lever. But it is an older model...
20167 (A55787)
20167 (A55787)
Adams 16T Tender Body (A55301)
Adams 16T Tender...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
