BX 2660
/ BX 2660 #1
T-MAC
WINONA, MS
BX 2660
I HAVE A BX 2660. I NOTICED A SPOT OF OIL UNDER THE FRONT END OF MY TRACTOR WHEN I PULLED IT OUT OF MY SHOP LAST WEEK. I LOOKED UNDER THE TRACTOR AND OIL FROM THE FRONT AXLE WAS DRIPPING OFF THE HOUSING WHERE THE DRIVESHAFT CONNECTS TO THE FRONT AXLE. I CARRIED IT TO MY DEALER AND HAVEN'T HEARD YET WHAT THEY FOUND. HAS ANYONE ELSE HAD A PROBLEM WITH A SEAL LEAKING ON THE FRONT AXLE OF THEIR TRACTOR?
/ BX 2660 #2
No, mine is about 2 1/2 years old without any issues.
/ BX 2660 #4
Did you change oil or add oil? Maybe the leak is coming from somewhere else.
My BX2660 is about 2 years old with no leaks that I'm aware of ....yet.
/ BX 2660
No I haven't added any oil. My little tractor is 2 1/2 yrs old and never had a problem. It has 184 hrs on it and so I was surprised to see the oil leak. Just wondered what might cause a seal like this to fail. Maybe I'll find something out from the dealer today. Thanks for the replys. At least it will be covered under warranty.
/ BX 2660
Good news. Went by dealership and they said it was not the front axle seal leaking. It was a bad O-ring on a valve block under the battery. The fluid was leaking and running down front drive shaft and then dripping out of cover surrounding front u-joint.
/ BX 2660 #8
It's kinda like a hole in the roof, namely, where the water comes thru the ceiling ain't necessarily where the hole in the roof is.
2011 Nissan Rogue SUV (A59231)
2011 Nissan Rogue...
ASSET DESCRIPTIONS & CONDITION (A59905)
ASSET DESCRIPTIONS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
