BX 2660
/ BX 2660 #1
T-MAC
WINONA, MS
BX 2660
I HAVE A BX 2660. I NOTICED A SPOT OF OIL UNDER THE FRONT END OF MY TRACTOR WHEN I PULLED IT OUT OF MY SHOP LAST WEEK. I LOOKED UNDER THE TRACTOR AND OIL FROM THE FRONT AXLE WAS DRIPPING OFF THE HOUSING WHERE THE DRIVESHAFT CONNECTS TO THE FRONT AXLE. I CARRIED IT TO MY DEALER AND HAVEN'T HEARD YET WHAT THEY FOUND. HAS ANYONE ELSE HAD A PROBLEM WITH A SEAL LEAKING ON THE FRONT AXLE OF THEIR TRACTOR?
/ BX 2660 #2
No, mine is about 2 1/2 years old without any issues.
/ BX 2660 #4
Did you change oil or add oil? Maybe the leak is coming from somewhere else.
My BX2660 is about 2 years old with no leaks that I'm aware of ....yet.
/ BX 2660
No I haven't added any oil. My little tractor is 2 1/2 yrs old and never had a problem. It has 184 hrs on it and so I was surprised to see the oil leak. Just wondered what might cause a seal like this to fail. Maybe I'll find something out from the dealer today. Thanks for the replys. At least it will be covered under warranty.
/ BX 2660
Good news. Went by dealership and they said it was not the front axle seal leaking. It was a bad O-ring on a valve block under the battery. The fluid was leaking and running down front drive shaft and then dripping out of cover surrounding front u-joint.
/ BX 2660 #8
It's kinda like a hole in the roof, namely, where the water comes thru the ceiling ain't necessarily where the hole in the roof is.
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
Woods 1050 3-Pt Backhoe (A66285)
Woods 1050 3-Pt...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
