BX backhoe fit any larger compacts?
   / BX backhoe fit any larger compacts?
What about a hoist? Any chance of mounting one to the ceiling? And I agree you should check your relief valve setting. Could even tweak it a little and go above max spec' pressure (about 1800 psi IIRC) and see what that does for you.
Hoist would work for the snowmobiles, but there are other reasons I need a little bigger tractor. And my other sled is probably 150 lbs heavier.
Will look into relief valve adjustment, Agreed - I'd like to be sure its set at the top of the range.
   / BX backhoe fit any larger compacts? #12
The lack of discussion of it, (how to lengthen the stabilizers, gpm etc etc etc.) suggested that it's not being done. Thanks for the answer radioman!
The only way you can move BH from tractor to tractor is to buy the 3 pt version like from woods brand.
Thank you, this is the info that I needed.
Kinda thinking of a B7800 with FEL & BH, any comments on that model?
2023 JOHN DEERE 7R210 LOT NUMBER 87 (A53084)
2023 JOHN DEERE...
2017 CATERPILLAR 12M3 MOTORGRADER (A51246)
2017 CATERPILLAR...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
12' CONTAINER (A51248)
2022 Tracker Pro Team 190 TX Tournament Edition Ba (A53117)
2022 Tracker Pro...
