SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,382
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
The hydraulics are shared with the HST.Well it happened to my BX2660 this past week. Just so I am prepared, the steering system is driven off of the HST or it has it's own closed system driven off of the motor? Can custom hoses be bopught at auto supply shops, or are the fittings unique to the BX? I will replace all, so any advise is welcomed.
The fittings are not unique, but fittings from different hyd suppliers vary a little and hose diameters vary a little also. ... The tight fit on the hose I replaced may be difficult to accomplish with a non OEM hose. The other line, the one that didnt fail, looks to be easier.
I have experience with the BX1500, but probably the same as yours. The line that failed was the one that ran back on the left frame rail and connected to the HST unit just above the left axle. It developed a pinhole a few inches from the fitting @ ~ 2khrs with no outward sign of damage. -- I believe this is the pressure supply line and the other one is return and is likely to last. The supposed pressure line is kinda special on the back fitting and you might have trouble duplicating it non OEM. Also, routing is not easy and a true dup will be easiest. ... The new OEM hose I got had a higher pressure rating.:thumbsup: ALSO, I was able to slip nylon sheathing over the new hose in the area of failure where it could possibly chafe or pulsate against any hard part. ... I dont want to deal with this again.
,,,,,While I had the platform off I painted its bottom side white to favor routine inspection.
