BX front axle bushing removal tool.
/ BX front axle bushing removal tool. #1
crabhab
MD
Kubota BX 2370-1
My Kubota BX 1500 has developed a leak in the front axle pivot bushing. Dealerships charge anywhere from 400 to 700 bucks to pull your front axle and replace the bushings.
I wanted to find the correct tool to remove the bushings. The bushings on the front axle of the bx series tractors are not in blind holes but they are seated against a shoulder machined in the axle housing preventing an easy push-out from the opposite side. I have found many blind bearing and bushing pullers that will work on Kubota BX front axles. They range in price from 70 to 500 dollars.
Here is an example of a lower end kit that I am considering buying to complete the job.
Motorcycle Blind Bearing and Bushing Puller : Amazon.com : Automotive
I really like the motion pro kit:
Motion Pro 08-0292 Blind Bearing Removal Set : Amazon.com : Automotive
/ BX front axle bushing removal tool. #2
Those are nice tools. If you're like me its a good excuse to buy them.
You could try tapping the bushing and threading a bolt into it and rigging up a way to use your slide hammer or a gear puller on it.
Or just chisel it out. The bushing should be softer than what its pressed into.
/ BX front axle bushing removal tool. #3
Bushing cutters
I thought about bushing cutters they seemed like they would work but the blind hole bearing/bushing pullers seem like the right tool for the job.
/ BX front axle bushing removal tool. #6
Yes the pullers you have there look to be the best way.
/ BX front axle bushing removal tool. #7
I dropped the axle myself, threw the whole thing in the back of my truck and took it to the shop along with new bearings. They charged me $80 in labor to pull the old ones and install the new ones.
/ BX front axle bushing removal tool. #8
I'm glad I decided to look up the part numbers on those bushings before I told you those tools were going be too small. I have done a lot of B's but no BX's. Your bushings are 25 mm od and 20 mm id, much smaller than the B's.
Brian
Bushings o rings and plastic seals are in along with a new pivot bolt. I am waiting for my bushing puller kit
I have about 470 hours on the BX. I have been using the FEL alot to move large rounds of wood. Some of the Cherry Tree rounds must be 200-300 pounds.
I got the front axle off of the tractor and decided to put on new grassmaster front tires, they are 4ply and OEM on the BX 1500. I had to use lots of vaseline to seal up air gaps and get them to take the bead.
My blind bearing puller didn't do squat with the bushings, I had a local farm equipment mechanic pull them and press in the new bushing for 70 dollars. I put in new o rings and plastic spacers, and a new pivot pin. I cut grass for a couple of hours yesterday and everything seems to be good and dry on the bottom of the axle.
I think there are a couple of reasons for failure:
1. Age my BX is 10 years old
2. heavy FEL usage without rear ballast
3. heavy hours mine only has 460-470 hours. But a 1000+ hour machine will have more pin wear.
4. Someone mentioned pressure but, there are two breather bolt on top of the axle drive housing. I got my service manual from a famous online kubota retailer for under 70 dollars.
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2012 International WorkStar 7400 Service Truck, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
VOLVO A40D OFF ROAD DUMP TRUCK (A60429)
VOLVO A40D OFF...
2011 Dodge Ram 3500 Crew Cab Pickup Truck (A59230)
2011 Dodge Ram...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
