BX front frame rails - perfectly strait? BX2660
   / BX front frame rails - perfectly strait? BX2660 #11
I am also the new owner of a BX2660, my rails seem to be straight, but I did notice looking at the tractor from the front, the front tire on the right side seems to be tilted in a little bit, the front tire on the left seems to be very straight, has anybody else noticed or had a issue with this ??
Could you take a picture? Are to talking about the camber? Or left/right alignment?
   / BX front frame rails - perfectly strait? BX2660 #13
Thats a good question, as I'm not sure, it may be a alignment issue, the BX is only a month old, and only 9 hours on it, and I never noticed it before until reading this post, if it would be a alignment issue, what would have to done to correct it ?? I'm sure it would be a warranty issue.
   / BX front frame rails - perfectly strait? BX2660 #14
From memory of reading the BX manual, they're suppose to be a bit toe in at the front. Would have to get the manual out to check, but it should be in yours somewhere. Might be in the maintenance schedule as well to check and adjust.
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
26ft x 24ft Metal Building (A51573)
26ft x 24ft Metal...
2013 AUDI A4 20T SEDAN (A51247)
2013 AUDI A4 20T...
MIDEA 8000 BTU WINDOW AC UNIT (A51248)
MIDEA 8000 BTU...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
