BX Hydraulic Control Lever ?
   / BX Hydraulic Control Lever ? #11
When the MMM is lowered the lever stays in that position. When it is raised it will pop back into the neutral position. Lift your seat and follow the linkage from the lever. If there is crud built up in there clean it out. Spray down the linkage with WD-40 and it should start working fine again. Work it back and forth after spraying it to loosen things up.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
6ft LandPride Box Blade (A51573)
6ft LandPride Box...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
