BX, Mowing With Deck Locked at Top?
   / BX, Mowing With Deck Locked at Top? #11
I probably should have added that we also have a brush cutter for the other tractor and would obviously use it for any true brush mowing. Danner, I'd have to agree with Orangeridge...can you see if someone can bush hog your place one or two or three times over the course of the growing season? After such mowings, it should then be fine to mow with your BX MMM. Regular mowing after that will eventually let the native grasses take over. Those first runs with the bush hog will break up or at least expose anything you wouldn't want to hit with the BX mower.
That seems to me to be a better approach compared with plunging into the great unknown jungle, alone and unafraid, on your trusty BX with the mower going at full tilt boogie! :D
   / BX, Mowing With Deck Locked at Top? #12
I just did this with my B7800..although it was not locked it was pulled up under the machine. The grass in this 2 acre pasture was close to 3 feet tall, and the B7800 with a 60 inch mower did the trick without breaking a sweat.
In the past I have used my G1900 to mow the pasture, but this time I decided to to finally hook up the deck on the B7800 (I removed the deck when I bought it used 4 years ago and had not until yesterday hooked it up.
As long as you dont 'bushhog ' with it it should work fine.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Polecat swift 206R (A50322)
Polecat swift 206R...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
