One problem I have is making sense of an hour recommendation when I look at the BX series VS the B series.
The BX hour meter counts actual hours when the key is turned on. The B-series hour meter counts hours proportional to RPM. So it generally takes more hours of engine running time to get an hour on the hour meter with the B. Probably on average for me 40% more actual operating hours.
But both owner’s manuals call out the same change frequency for just about everything.
And if I follow the manuals, I actually change oil at different real-time hour points. A hundred hours on the B-series tractor equates to about 140 hours on the BX in real-time engine-was-running terms.
Conversely, 100 hours on the BX would clock only about 70 hours on the B-series.
To this point I have been doing a little better than the manuals recommend. However, I am still having trouble determining if I am doing “good(B) and better(BX)” or “just enough(BX) and worse(B)”
In the end Junkman, when it comes to our tractors, excessive is reasonable, isn’t it? Keep up the good work!
