BX oil change.....
   / BX oil change..... #41
If I have an engine that allows for filling the filter beforehand I do so . But either way I always make sure my oil is warm and well circulated before doing a change . That way I'm fairly sure there's at least a coating of oil before restarting the engine . On my 6.0 deisel the filter is on top of the block . there's no way to pre fill it . But it fires right up after an oil change . As the injectors are run by engine oil , there must not be too much air in the oil system . John
   / BX oil change..... #42
</font><font color="blue" class="small">( On my 6.0 deisel the filter is on top of the block . there's no way to pre fill it . But it fires right up after an oil change . As the injectors are run by engine oil , there must not be too much air in the oil system . John )</font>
I have given that a passing thought on my 6.0 stroke. How do the oil pressure operated injectors work to start the engine after you have drained the oil? I would guess that is what the quart reported to remain in the engine after draining the crankcase is for.
   / BX oil change..... #43
you will still have some % of oil in the line on the 6.0. When I had my PS I sometimes filled oil filter and sometime not. It would not hurt anything either way.
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
(3) PIVOT TIRES (A51248)
(3) PIVOT TIRES...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
