BX Owners: What deck number do you cut grass at?
   / BX Owners: What deck number do you cut grass at? #12
I use 3.5 also.
   / BX Owners: What deck number do you cut grass at? #13
3" and the blades measure exactly 3". Tip: check your tire pressure before setting blade height /levelness.
   / BX Owners: What deck number do you cut grass at? #14
I mow with the deck all the way up. It chokes the weeds the granules don't get and seems to help the lawn withstand drought a little better. My grandpa called it "Beer can tall".
   / BX Owners: What deck number do you cut grass at? #15
When I had a BX I cut at 3.5 also.
   / BX Owners: What deck number do you cut grass at? #16
The leveling screws for this will throw it off. One number is not the same on everyones tractor.
   / BX Owners: What deck number do you cut grass at? #17
4 on my rough ground, mow about once for every 5 or 6 times everyone around me wastes fuel scalping their ground.
   / BX Owners: What deck number do you cut grass at? #18
As a sidenote, I started putting 20 pumps of grease into each Spindle rather than 10 pumps every 10 hours. I changed my mower blades this spring it it seemed like I needed to put a lot of grease in before it started coming out the bottom of the spindles
Bill
That's a lot of grease. I have always done 3-4 pumps every 10 hours. Not saying you're wrong though.
My ZD326 has over 1300 hours on the original spindles, and universal joints for the drive shaft.
As far as deck height, I generally cut grass to 4" which is one mark above 4 on my particular mower.
2008 GREAT DANE 53x102 DRY VAN (A53426)
2008 GREAT DANE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2004 INTERNATIONAL 4300 BOX TRUCK (A53426)
2004 INTERNATIONAL...
