BX owners with a Woods BH
   / BX owners with a Woods BH #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I know I'm not the only one on the list hear that has a BX with the Woods Ground Breaker X BH on it. I have a question for you few, brave soles, that didn't go the way of the BX24, oops, I mean BX23.
Anyway, can you measure the spread on your 3ph and let me know if you are seeing a true 26" for a CAT 1 3ph. I have several implements that refuse to fit unless I turn the pins on the inside while I hear of others with the same implement not having to do so.
I never measured the spread before the Woods BH was installed so I'm not sure how much it was impacted.
I'm begining to think that the Woods BH makes an already semi limited 3ph even more limited.
   / BX owners with a Woods BH #2
Matt
I have a 2002 BX2200, the available spread on the 3PT is just over 32". I'm concerned with the spread with a Woods BH6000 since I plan to install one soon. /forums/images/graemlins/confused.gif
Russ
Russ,
The Woods BH mount is definitely impacting the spread of the 3PH on the BX. I dont think you can get better than an even 26" fully spread. I'll take some pics and post them to fully detail this. This one
   / BX owners with a Woods BH #4
I haven't noticed any problems with the Woods "Estate" series attachments I have, but they are designed for the sub CUT's. What is it that might limit the spred? The hoe attachment tabs on the sub frame? You could use longer arms to compensate if they were available or longer pins maybe.
I absolutly "dig" this set up. I can hitch it up in less than 5 minutes now. All of the mounting pins slide right in now that I spread those "slide lock" forks that go over the top mounting brackets. They were heat worped closed from the factory welds.
Man is this thing tough /forums/images/graemlins/grin.gif
Woods when you talk about the pins sliding into place are you talking on the BH mounting or are you talking about the B series 3PH mods that everyone makes?
The subframe is what is limiting the 3PH, I dont have any Woods attachments, everything that we are using is standard CAT1 from Midwest Manufacturing. If you can turn the pins iside you are fine, if youcan't, the implement will not fit.
The Woods implements are the only game in town if you plan to use the Woods BH I'm finding out. Good in that they are extremely nice, but bad in that the choices and price points are missed.
   / BX owners with a Woods BH #6
In addition to my Woods BH6000, I have a Woods LR60 rake...but I also have a standard Cat 1 2" receiver hitch. I actually just had the hitch on this weekend, and didn't notice and limitation of the spread of the 3PH arms from before the BH6000 subframe was installed. I will say that when I raise the 3PH, either with the rake or hitch, the 3PH arms rub up against the top BH subframe attachment tabs, but it does not seem to limit it. I was told by my dealer that the only difference between the Cat 1 versus the limited Cat 1 on the BX series tractors is that the height of the max lift of the standard 3PH is a bit higher on the standard Cat 1. This seems to be an issue when using a PHD that is not specifically designed for the limited 3PH.
   / BX owners with a Woods BH #7
King Kutter XB's will probably fit too... /forums/images/graemlins/grin.gif
   / BX owners with a Woods BH #8
Is there any way you can spread your TPH arms all the way out and take a picture so we can see what is limiting the spread of your arms, the only thing that I can visualize that would limit the spread to that small amount is the turnbuckles, I don't have a problem using regular Cat1 impliments as my arms will spread to over 32".
   / BX owners with a Woods BH #9
I noticed in the Northern catalogue that the XB impliments which are physically smaller, are more expensive than the same size Cat 1 impliments, figure that.
   / BX owners with a Woods BH #10
Why didn't you just go with the BX23 and save yourself from having this problem and the too short ROPS Problem??
I was offered a similar deal on a new bx2230 when I was shopping for my bx23 and wisely I turned it down in favor of the BX23.
Very glad I did as it appears it saved a lot of grief & aggravation.
Champion C80 B Motor Grader (A50322)
Champion C80 B...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
Deere 317G (A50120)
Deere 317G (A50120)
2012 Killbros 110 Grain Cart (A50514)
2012 Killbros 110...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
