Backhoe BX & Woods backhoe questions
   / BX & Woods backhoe questions #1
RonR
Kansas
2003 BX2200
For you guys who've added the Woods backhoe:
Does it have a subframe? So you have to remove the 3PH?
Good thoughts?????? Was it a good move?
THKS.
ron
   / BX & Woods backhoe questions #2
Ron,
I have the 4 pt. sub frame mount Woods BH6000. Woods does a good job at easily moving the 3PH off the back and easily hook up thr BH. I am very satisfied with my set up.
BMW
Mine is the standard fixed for BX2200. I'm guessing short.
   / BX & Woods backhoe questions #5
There are dozens of threads on this and literally hundreds of posts. To find most of them, use the search function as follows: Make sure to locate the "Main Search Page" where you can choose the forum "Kubota Owning and Operating". For the time select "all posts". Use the search phrase "bh6000". You will find reams of info. Good Luck.
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Giyi Pallet Forks (A53316)
Giyi Pallet Forks...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
Fast 9613N (A53314)
Fast 9613N (A53314)
