BX1500 Greenie Questions
   / BX1500 Greenie Questions #11
Sorry to be the safety police here but I feel obligated to caution anyone running a BX in high range with a FEL while mowing---especially with ANY kind of hills. BX's are light in the rear, and without an implement attached they are very tippy if you leave the FEL on. Not really a problem if you go slow on level ground, but dangerous on an incline. 4WD is MANDATORY on hills because you have no brakes at all if the rear tires loose traction. There is no good reason to mow in high range. Quality of cut is horrible and you risk tipping over if you hit even a small hole. Either take the FEL off or keep it in low range and stay away from hills.
The BX is a deceptively capable little tractor. They should be operated like a farm tractor, not like a riding mower.
   / BX1500 Greenie Questions #12
I mowed with my BX1500 for the first time last night with the tranny in "fast" mode. The tractor has the FEL and wheel weights on it. I noticed a couple times that when I stopped in the middle of one of my hills and then restarted up the hill the tractor would bog down a bit. Also, at one point, I got stuck in a big rut that I didn't see. When I tried to acceclerate out the rut the tractor wouldn't do it. So I switched to 4wd and shifted the tranny into "slow" mode and I was able to pull out. One more thing that I noticed is when I was driving the tractor back to the garage (PTO off) I noticed a sound which reminds me of a water faucet running.
My questions are; should I remove the wheel weights and FEL when mowing and are the other conditions I mentioned normal on this model tractor?
The description sounds normal. I have my rear tires loaded and If I had wheel weights I would put them on as well. I mow on flat ground in high and on the hills in low range. I dont have a FEL:( but hey you cant have everthing.
   / BX1500 Greenie Questions #13
How about the wheel weights??
Leave them on. You'll hate how light the rear of the tractor is without them. I figure the 'bogging' is fairly normal, moving all that weight up a slope. I can't say my engine bogs (a few more mice under there), but it definitely takes a little extra push on the HST treadle to get moving in high gear.
I don't think there is a single negative effect of having the wheel weights on. In over 4 years, I've taken mine off for about 1 week, hated it, and put them back on.
   / BX1500 Greenie Questions #14
Leave them on.
*You'll hate how light the rear of the tractor is without them. I figure the 'bogging' is fairly normal, moving all that weight up a slope. I can't say my engine bogs (a few more mice under there), but it definitely takes a little extra push on the HST treadle to get moving in high gear.
I don't hate not having wheel weights or filled tires on these.
   / BX1500 Greenie Questions #15
I bet you will really like that 1500 when you get used to it. I mow steep hills with mine, and I always take the FEL off because they can get tippy on hills when mowing. I have done it before but feel much better with it off. I also have WW fluid in the rear tires and it does feel a bit better on the hill with the weight in the tires. When the ground is a little soft it will leave some small ruts but not if it is dry. I always mow in 4WD Low and have no problems. They will get weak on you in high going up steep slopes and that is more a function of the HST than the engine is is the nature of them I think. Bigger units may have more flow, but they will all do what you describe to some extent if the slope is steep enough and the load hard enough. Just mow in 4WD low when necessary I have done it for three years with no trouble and braking in 2WD L or H can be a problem on hills anyway. Good luck and Take care-TPS
   / BX1500 Greenie Questions #17
I use low range on mine to cut grass. It does get boggy cutting uphill in high range and speed. My yard is so bumpy that I don't want to cut in high anyway. I remove the loader cause it is more manuverable around obstacles, and seems less bouncy. No problems with power or traction cutting in low range.
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
1270 (A50490)
1270 (A50490)
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
