BX1500 LA181 FEL Bucket Hooks
   / BX1500 LA181 FEL Bucket Hooks #1
blackmajicwoman
Westport, MA
Kubota BX1500, ZD331
Finally got around to welding on the bucket hooks for the LA181 FEL on my BX1500. The end hooks are 3/8" weld-on forged grab hooks (WLL 6600#). I welded them on a piece of 2"x4"x1/4" flat stock for added stregnth. I also did not weld them right to the edge, as this would prevent a chain from engaging onto the hook, so I left a 1/2" gap, which accomadates the chain with no problem. The center hook is a 3/8" slip hook that I welded directly onto the center 1/4" plate (WLL 5000#). To finish it off, I sanded, primed, and repainted the entire bucket.
pic #2
pic #3
pic #4
   / BX1500 LA181 FEL Bucket Hooks #5
That's what u call better than new /forums/images/graemlins/grin.gif
Keep up the good work...
   / BX1500 LA181 FEL Bucket Hooks #6
Nice job! Based on comments here on TBN, I went with the same setup on my B7800. You will find no end of uses for those hooks.
2010 CATERPILLAR CM1210106 ROUGH TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
7046 (A50322)
7046 (A50322)
71062 (A49346)
71062 (A49346)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
