BX1500 No Drive Power
   / BX1500 No Drive Power #11
I would check and make sure the brakes are free. The shafts/can sieze up and lock the brakes. I would also make sure the lift was in neutral/middle position because it really robs the power if they are bypassing through the relief valve.
   / BX1500 No Drive Power #12
OP, any resolution to the problem with your BX1500??
larry
   / BX1500 No Drive Power #13
From your symptoms, you may be looking at an air leak on the suction side of the pump. There is a flex pipe between the strainer and the pump that can develop a small crack or pinhole leak. It causes a general lack of power and typically a whine when the HST pedal is depressed. Check for leaks before deciding to dive into the transmission.
Killbros 1950 Auger Wagon (A50514)
Killbros 1950...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2012 JOHN DEERE 333D SKID STEER (A51242)
2012 JOHN DEERE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
