BX1860 propeller shaft front joint cover (dust boot) replacement
   / BX1860 propeller shaft front joint cover (dust boot) replacement #1
wrooster
Platinum Member
Hi folks,
I have a 14 year old 800hr BX1860 on which I've just discovered the propeller shaft front joint cover (aka dust boot) (item 20 below) has worn through and fallen off. Interestingly, the damaged boot was just sitting atop the MMM deck which I had pulled off for springtime blade sharpening. This I believe was actually quite fortunate, otherwise I probably would not have noticed that the boot was in fact missing.
On to the business at hand.
Is is possible, on a BX1860, to remove the snap ring (item 100 below), then remove the bolts holding the front coupling (item 080 below) to the engine output flange, remove the retention spring (item 40 below) and then position the front coupleing and shaft in such a way that the entire coupling can be removed from the shaft?
Kubota #K2561-14132 COVER,JOINT (Cover, joint)
Thanks for any ideas, suggestions, etc.
wrooster
2014 Mercedes-Benz C-Class Passenger Car, VIN # WDDGF4HB1EG240849 (A44391)
2014 Mercedes-Benz...
2011 CONVEY-ALL  SK-4000 SAND KING TRAILER (A45333)
2011 CONVEY-ALL...
2000 Mack CH613 w/ Wetline Truck (A42203)
2000 Mack CH613 w/...
2022 John Deere 6135E (A44501)
2022 John Deere...
PALLET OF T-POSTS (A45333)
PALLET OF T-POSTS...
Toro Z-Master 60in Zero Turn Mower (A44572)
Toro Z-Master 60in...
