bx22 - 24 month check up
   / bx22 - 24 month check up
thanks will try the pb blaster, also will look at the adjustments for the 3PH. Any ideas as to adding a stiffener to the bucket?
I was thinking of having a bar welded under the bucket from edge to edge behind the weld for the cutting edge. what would be a good thickness and width for the new plate? Is this the best location?
   / bx22 - 24 month check up #32
You can purchase the cutting edge from www.tractorsmart.com and take it to a local welding shop and they will weld it on for you inexpensively. Who knows, there might even be another TBN member that lives near you that will do it for a case of brew. Ask around town who does welding. It isn't that hard of a job. The part # is 75532-59320 and cost $110.45 plus shipping. If you own a hand grinder, you can save some time and money if you grind off the old welds in advance. Or take the bucket to a welding shop and they can make the new cutting edge and install it. The reason the dealers quote was so expensive is they didn't want the job.
John Deere MX6 Rotary Brush Cutter Tractor Attachment (A55787)
John Deere MX6...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
