Bx2200 axial ball joint replacement
   / Bx2200 axial ball joint replacement #21
I have an illustrated parts manual for my BX2200, deck and loader. I just looked at the steering diagram and it appears to have a flat spot right at the axial ball like you guys have mentioned. I will look again tonight and post again. I am really going to feel stupid if it is indeed there and I simply did not see it.
The flats are narrow and may be covered in dirt and grease. They are only on the right side.
I think you guys were right...the right side appears to have a very narrow flat spot. I think a regular wrench would be too wide to get in there.
   / Bx2200 axial ball joint replacement #23
You can:
1. Buy a thin wrench.
2. Buy cheap wrench and turn it into a thin wrench, I've seen both approaches.
I was thinking about trying to use my adjustable toilet wrench...lol
   / Bx2200 axial ball joint replacement #25
I used a 6 inch Crescent wrench. The ends were narrow and fit. Or as mentioned get a thin wrench. (cheap one)
i finnally broke my axial balls loose and replaced then. Here is what I did...I bought a cheap 22mm urrea thin wrench, used the grinder on it to make it thinner, and then broke the balls loose. As a previous poster said, you can only use a wrench in the right side of the hydraulic steering ram. Thanks for the help guys!
Kivel 48in Pallet Fork Attackhment (A49251)
Kivel 48in Pallet...
Pallet of (5) 8 Lug Misc Wheels (A48837)
Pallet of (5) 8...
2014 Ford Taurus Sedan (A48082)
2014 Ford Taurus...
2025 Swict 72in Bucket Skid Steer Attachment (A49346)
2025 Swict 72in...
KAESER COMPRESSOR (A48992)
KAESER COMPRESSOR...
2025 Gold Mountain 20ft X 20ft Single-Truss Dome Container Shelter (A46687)
2025 Gold Mountain...
