BX2200 Bent Frame?!!
   / BX2200 Bent Frame?!! #1
texasbx
Dallas Texas
BX2200
I noticed that my tractor was sitting weird and measured the front corners of the frame. There is almost an inch difference between the two!! With the fel on and the bucket resting on its edge, there is almost 3" difference. I'm calling my dealer tomorrow, but has anyone else heard of / seen this before?
   / BX2200 Bent Frame?!! #2
Did you check the air pressure in all the tires? I know it sounds a little odd, but a low rear tire will make things off at the front end.
   / BX2200 Bent Frame?!! #3
I can't imagine that its bent. Its a 5" tall plate steel frame, and should handle more power than the bx can put out by a wide margin. You'd never get the fel on or off, or get the mower level if it was off that much IMHO. Bird is probably correct, but keep us up to date as you get more info.
DaveL
Well, chalk this up to "I feel just plain stupid". I checked the air pressure in the right rear tire, and the guage didn't even move (less than 10 lbs). So 20 lbs in all tires and we're off and runnin' again. Thanks for your help!!
   / BX2200 Bent Frame?!! #5
</font><font color="blue" class="small">( I feel just plain stupid )</font>
We've all been there, so it's always fun when it's someone else. /forums/images/graemlins/grin.gif
   / BX2200 Bent Frame?!! #6
Everyone does an /forums/images/graemlins/crazy.gif"oops" now and then. Ain't it great to be human /forums/images/graemlins/smile.gif?
Good luck,
DaveL
   / BX2200 Bent Frame?!! #7
Yeah, been through this scenerio myself. Trouble is, the tires don't look flat!
   / BX2200 Bent Frame?!! #8
I give you points for paying attention to details and finding a cure. I know I would feel terrible if I ignored something, that I had an idea might be wrong but then let it go all the way into a disaster.
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
Giyi Mulcher (A57149)
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
CAT D8 (A58216)
CAT D8 (A58216)
