BX2200 Blown Hydro Hoses
   / BX2200 Blown Hydro Hoses #1
RET
Louisiana (near Baton Rouge)
Kubota BX2200, JD LX277, Cub Lo-Boy
Blew a couple of hydro hoses....been an ongoing problem....another story.
Anyway, had to disconnect 3 of 4 hoses to steering unit under dash...thought I had remembered where each goes. Guess what? I didn't. Steering did not work when repairs were finished. Changed a couple of hoses around on wild guess. Blew ANOTHER hose...bad crimp connection.
Anyway, after I get another new hose, need some help determining which hose goes where. could somebody help me? refer to atttached drawing. PDF parts file does not give that kind of detail.
Left steering cylinder
Right steering cylinder
From Hydro Pump
Return to hydro pump
thanks!
RET
Having trouble posting image from my PC. I clicked 'image' and inserted the address to the appropriate folder/file on my PC. Obviously this is wrong. what did I do wrong? It didn't upload.
   / BX2200 Blown Hydro Hoses #3
RET,
Is the image larger than 100K? If so it will not work...
As an aside thought, you might consider buying the repair manual for your BX.
Four hoses = 16 combinations...might be cheaper than trying them all and blowing hoses...
Wish I could help but I also have not yet bought the repair manual... /forums/images/graemlins/blush.gif
   / BX2200 Blown Hydro Hoses #4
T= connect to the return hose
P= connect to delivery hose
R = Connect to cylinder RH Hose
L = connect cylinder LH hose
Diagram looks like this
Front
T P
L
R
P = Pump Port
T = tank port
L= L Port
R = R port
If this does not make sence PM me with a fax number and I will fax the page to you.
   / BX2200 Blown Hydro Hoses #5
Here's the section from the WSM.
  • 473234-WSM steering.pdf
Tom, Ryan,
I'm set now. Thanks for the info!
roger
DESK (A53843)
DESK (A53843)
KENWORTH ROLLBACK TOW TRUCK (A52706)
KENWORTH ROLLBACK...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
1779 (A51248)
1779 (A51248)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A53843)
RAKE ATTACHMENT...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
