BX2200 Grille Guard
   / BX2200 Grille Guard #1
TomPh
Kentucky
BX 2200
I understand that Kubota makes two different grille guards for the BX series. A front bumper/weight bracket and a plain grille guard.
I am wondering if anybody has either of these and if so a picture would be much appreciated.
Thanks,
TomPh
   / BX2200 Grille Guard #2
The bumper weight bracket is a u shaped channel for hooking weights on. The grill guard is a loop of steel that protects the front of the tractor most useful when using the FEL. I beleive any welder could mod the grill guard to accept a couple of weights. Most of the BX pics posted in various threads on TBN have grill guards.
J
   / BX2200 Grille Guard #3
TomPh,
The "grill guard" is in every photo with a FEL in the Kubota brochure. The "weight bracket" is only pictured in the owner's manual. I have a scanner and manual at home, and could try to e-mail you a picture at home if you like, but I'm way to techno-ignorant to figure out how to post a picture here.
I just ordered my BX2200 yesterday. I really didn't need the FEL yet (no posts about that, please, guys!) so I got the front weight bracket instead, since I mow around posts and want to protect the front of the tractor. The Weight bracket sticks out a ways from the front of the tractor, you might want to check to be sure it's compatible with the FEL. Most people with a FEL can use that for front ballast, and therefore do not need the weights when using a rear implement. I will eventually need weights, so I'm putting the bracket on from the get-go. IMO, the grill guard is overkill without a FEL.
Happy hunting. Tom Marincic
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2024 Sky Jack SJ45 AJT Man Lift (A51573)
2024 Sky Jack SJ45...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
