BX2200 hydraulic leak above hydraulic filter rear right
   / BX2200 hydraulic leak above hydraulic filter rear right
I had the neighbours depress the seat by- pass button, turn the key and with 2 more lights... a better video... anyone?
   / BX2200 hydraulic leak above hydraulic filter rear right #13
All you have in that area is the gasket in the HST or the O-rings under those 2 Allen Plugs. The plugs and o-rings would be easy to check....
Really does look like the gasket
Okay I will check the parts diagram and shop manual and open the Allen plugs! Thanks!
   / BX2200 hydraulic leak above hydraulic filter rear right #15
Best I can tell there is nothing under those plugs on the top and only one on the bottom has some sort of functional parts. Of course you never know...
   / BX2200 hydraulic leak above hydraulic filter rear right #16
BTW nice vid, shows where the flow starts, right under that shaft at plugs and gasket. Strange but stuff happens. (y)
Thanks! I'll post some pictures for the next guy lol.
I had the neighbours depress the seat by-pass button, turn the key and with 2 more lights... a better video... It looks like the housing cracked. I will open the plugs with the Allen key if I can but can't imagine it's an o-ring causing that let alone 2 simultaneously. I need to determine if in fact that housing is cracked whether JB weld is an option, replace just the housing or get a whole new unit... Very expensive like $3k CDN ($2,300 USD) just for the unit... I also don't know that I should go further on my own or get the Kubota tech also $1,000's in labo(u)r... Last year it leaked because a bolt fell out, which I found and replaced so it must have cracked back then and eventually evolved in one shot due to pressure into this...
Thanks. I am looking for a used D01500 HST [COMPONENT PARTS]... new is like $3k? I will undo those Allen key plugs tonight but really doubt that's where it's gushing from. If they look fine, I'll have no choice but to pull the HST unit next and am pretty sure I'll be posting a photo of the cracked housing. I might have no choice but to bring the unit to a machine shop but am a bit afraid of a repair. Kubota do not sell the housing separately. I've been searching for a used unit based on my serial number which seems to be after the #50016 for my 2001 BX220D from the unclear photo I have stored on my laptop... Will triple check the tractor serial number if I am ordering one...
Electric Concrete Mixer - (A51573)
Electric Concrete...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
