BX2200 Hydraulics
   / BX2200 Hydraulics #1
Hootie
SW ARK
Kubota BX2200, Kubota ZD 221, Kubota Grand L 5030 HSTC, Kubota RTV, Polaris 500ATP
Per my previous post "Got it Today" (posted yesterday) I developed a hose leak on the FEL which the dealer gladly came today and fixed. Well.........after about two hours of operating the BB today, I developed a leak from the implement feed line on the hydraulic outlet! What a bummer! I always try to be optimistic and I know things happen. I am not abusing this machine. Is this a common problem?
   / BX2200 Hydraulics #2
My BX2200 leaked at the same area shortly after getting tractor and using FEL. It turned out that the fittings were not very tight. The dealer put teflon tape on all the fittings and reinstalled. I haven't had any more trouble. Hope yours is a simple fix like mine.
   / BX2200 Hydraulics #3
That's funny because I had the same thing with my BX2200. The fittings going into the hydralic outlet block on the transmission were leaking the first time I used my loader. Being a mechanic I went after it myself and when I removed the steel lines I could not believe that the fittings were merely hand tight into the block, so I just did the teflon tape thing and tightened everything up. I gave my dealer heck about it but their excuse was that this part was preassembled in the FEL kit and they didn't bother to check how snug the fittings were before installing everything assuming they were already tight.
   / BX2200 Hydraulics #4
I Have seen this also, it's common for us to take the two fittings and tape them, except the fitting with the o-ring, I simply assure it is aligned and tightened.
   / BX2200 Hydraulics
Per my attachment, should this bracket holding the steel lines be cushioned?
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2000 International 4700 (A50120)
2000 International...
Wolverine Mini Skid Steer Stump Grapple (A50515)
Wolverine Mini...
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
