BX2200 Lift arms leaking down
   / BX2200 Lift arms leaking down #1
TomPh
Kentucky
BX 2200
My BX2200 is approaching 600 hours, used mostly for mowing. However, it has done quit a lot of loader work as well. When I mount my homemade weight bar on the tractor as soon as it is lifted it begins to leak down very quickly. The valve that controls the lift speed, that can be used to keep the arms in the upmost position if you wish, does not affect the leak down at all.
I'm wondering if anyone else has experienced this problem. I suppose that there may be an o-ring blown somewhere but am not sure.
Thanks,
TomPh
   / BX2200 Lift arms leaking down #2
If I turn my lift speed valve clockwise (to the max) it does not leak down at all. Even with 400 lb weight box on the 3PH.
John
   / BX2200 Lift arms leaking down #3
Tom,
I would agree that you have a leak someplace. Although it is normal for leak down, it is typically not noticable as it takes hours not minutes.
20" Sea Container (A47384)
20" Sea Container...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
16ft Enclosed Trailer (A51572)
16ft Enclosed...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
