BX2200 Lift arms leaking down
   / BX2200 Lift arms leaking down #1
TomPh
Kentucky
BX 2200
My BX2200 is approaching 600 hours, used mostly for mowing. However, it has done quit a lot of loader work as well. When I mount my homemade weight bar on the tractor as soon as it is lifted it begins to leak down very quickly. The valve that controls the lift speed, that can be used to keep the arms in the upmost position if you wish, does not affect the leak down at all.
I'm wondering if anyone else has experienced this problem. I suppose that there may be an o-ring blown somewhere but am not sure.
Thanks,
TomPh
   / BX2200 Lift arms leaking down #2
If I turn my lift speed valve clockwise (to the max) it does not leak down at all. Even with 400 lb weight box on the 3PH.
John
   / BX2200 Lift arms leaking down #3
Tom,
I would agree that you have a leak someplace. Although it is normal for leak down, it is typically not noticable as it takes hours not minutes.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
