JWE
I found this list of material weights on Carvers web site. It doesn't take a lot of material to exceed the BX2200 rated capacity. I think the bucket holds around 6 cu ft.
Wood Chips...... 18 pounds per cu ft
Hay Bales ... 20 pounds per cu ft
Coal Ash ... 40-45 pounds per cu ft
Dry, loose dirt ... 76 pounds per cu ft
Wet, packed dirt ... 115 pounds per cu ft
Dry clay/gravel mix ... 100 pounds per cu ft
Wet clay/gravel mix ... 110 pounds per cu ft
Dry sand/gravel mix ... 90-120 pounds per cu ft
Wet sand/gravel mix ... 126 pounds per cu ft
Dry sand ... 90-105 pounds per cu ft
Wet sand ... 126 pounds per cu ft
John
John
