rs191
BX2200 (D905 engine) won't start, electrically dead. After mowing the lawn last weekend, parked it in the driveway for about an hour. When I went to move it into the garage; turning the ignition key did nothing - no fuel pump noise, no dash lights, etc.
Following the repair manual, here is what I tried: 1 - battery shows 12V across terminals, 2 - terminals were cleaned with terminal brush, 3 - all fuses look okay, 4 - main (ignition) switch is getting 12V (RED conn.30 to chassis), 5 - continuity tests for all ignition switch positions were good, 6 - continuity tests on shifter and PTO safety switches were good, 7 - voltage test at Engine Stop Solenoid plug shows 7V-7.5V across terminals 2+3 WHICH SHOULD show 12V from the battery.
Manual (see msg 5 in this thread, http://www.tractorbynet.com/forums/kubota-owning-operating/90642-bx-2230-wont-shut-off.html), says low voltage to solenoid means main switch or harness problem. A new switch had ZERO effect on the problem. I did not test the solenoid itself because there is low voltage being fed there.
What's next? Anything else to try before paying the dealer to come the 25 miles to the house? How can I find out why I'm only getting 7V-7.5V to the solenoid connector?
Thanks for any ideas, Rich
