BX2200 Tire swap
   / BX2200 Tire swap #1
Anonymous Poster
Epic Contributor
Is it possible to put larger rims and tires on the BX2200? I'm not talking about anything extreme, just the ones that come with the B7400.
   / BX2200 Tire swap #2
Not sure of the size differences but axle gearing is usually done in proportion to tire size so keep in mind that you may loose some power to the wheels or break something.
   / BX2200 Tire swap #3
NO!!!!!!!! it is not possible. J
   / BX2200 Tire swap #4
anythang is possabale,,, yo mite brake somtin tho. I thank that you can kick it up a notch as long as you keep the front to back tire ratio. guess it wood take a little figurin and i cant figur that high.
   / BX2200 Tire swap #5
Well, I suppose you could cut the fenders off but what about the ROP that mounts to them and you would have to cut out part of the floorbard also and since the MMM design is based on a 55 inch wheelbase with a particular spacing between tires then going to larger tires would keep the same wheelbase but the space between tires would decrease so it would not be possible to mount the belly mower. Also, the front tire track spacing is based on the factory dimension, a larger front tire/wheel assembly would interfere with the frame and thus limit steering so a spacer would have to be installed but then it would likely strike the FEL bracket.
No--everything really is not possible--a cliche I use also too often--but in this case it ain't possible or practical muchless advisable or cost effective. I suggest you trade for the 7500, even with the loss it would be cheaper than trying to convert your BX into a 7500. J
   / BX2200 Tire swap #6
I guess if the "fenders were cut off" and you added a set of drag pipes it would "officially" classify the BX as a CHOPPER...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
STORAGE FEES (A51219)
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
