It looks pretty promising that I will be purchasing a 3.2 acre valley across the street from my home. I am purchasing it mainly to protect my view. It is not terribly builder friendly as it has about a 50 foot drop from the highest to the lowest part. It is stepped and has some flat areas.
I am thinking that I would like to work with this ground to cut in a road, and improve some of the better spots for building. It is also heavily wooded so I will be thinning the less desirable trees and such. I even have some half arsed ideas that I might like to put in a tree nursery, or a small personal vineyard. Last I do plan to clear some spots for picnics and bon fires and also I want a garden to till and use (though I may choose to keep that in my current yard).
So the basics I'm seeing is that I'll be using the loader and a back blade allot. Perhaps a BX blade too?... It seems that this is a lot more work than I had originally planned for my BX2200. That said, it'd probably do it, just in smaller bites. My bigger concerns for the 2200 are ground clearance, and stability in uneven ground. The 7800 can have its wheel track adjusted extra wide for a more secure footing. I looked at the B-7510 and B-7610, but I’m thinking that if I’m gonna take the hit on the BX in trade in, I should probably be darn sure to go big enough. Plus I like the round headlights!!!
My concerns about the B-7800 is that it might make mowing my 3/4 acre lot difficult (BUT!!! - the turning radius in the brochure stated a 6.9 foot turning radius with brake). The BX states a 7.5 foot turning radius.
I'm open to advice, suggestions, other options, or just a good old fashion reality check.
Thanks all!
Thanks all!
