BX2200 won't start
   / BX2200 won't start #1
HelGen
BX2200 won\'t start
I was cutting grass on Sat, going along just fine for about three hours. Wife came out to tell me something and I turned off the tractor. Now it won't start. I was initially just going to blame it all on her... but decided I do have to eat every day.
It turns over fine, and fires up, then just stops immediately. I replaced the fuel filters and checked that it was actually pumping fuel. Filled it up with diesel (was on about 1/2 tank when it quit working). Bled the fuel lines. Checked fuses. Checked gear-shift and PTO levers to ensure no obstructions.
It really acts like it's not getting fuel flow, but I turned the key when changing fuel filters and it's pumping.
Any ideas?
   / BX2200 won't start #2
Re: BX2200 won\'t start
Is it shutting down right when you release the key, or does it run for a few minutes and then shut down?
It shuts down right when I release the key.
   / BX2200 won't start #4
I may be wrong, but I think there was a recent thread about a similar problem and it turned out to bue a blown fuse...
So I would check the fuses. I think there is one for the fuel shutoff solenoid...
If I have that thread book marked I will post it. I hope I am not off base in this recollection...
   / BX2200 won't start #5
Henro...... Your power of recall is remarkable. That is exactly what happened to the other person and that is exactly what the problem was. /forums/images/graemlins/grin.gif
Just rechecked the fuses again. None blown. I even replaced them all one-by-one, trying to start after each, same thing. Rechecked all after replacing. None blown.
   / BX2200 won't start #8
I was hoping that someone would come up with the thread. I remembered the condition happening on another post, that's why I asked about when it was cutting out. Junkmans right, Henro, your the man. You remembered it better than I could.
   / BX2200 won't start #9
Bird pointed out a similar problem some time ago. It was due to his releasing the key too sharply; the key's return spring was sufficient to then rotate the key to the "off" position.
EBS
   / BX2200 won't start #10
<font color="blue">It really acts like it's not getting fuel flow, but I turned the key when changing fuel filters and it's pumping
</font>
Is it pumping when the key is turned to start? or run? Both?
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
