BX2230 54"mm (56Hrs) Lift Control Sticks
   / BX2230 54"mm (56Hrs) Lift Control Sticks #1
advanced24
Connecticut
BX2230
BX2230 54\"mm (56Hrs) Lift Control Sticks
Lift Control Sticks and doesn't return to center. I tried adjusting the rod nuts but still sticks. My Dealer said there is not much he can do and it may work its way in. I think if it hasn't worked in by now it never will..Any one else had this problem..
   / BX2230 54"mm (56Hrs) Lift Control Sticks #2
Re: BX2230 54\"mm (56Hrs) Lift Control Sticks
I had a similar problem with mine. I tilted up the seat and operated the lever to see what rods and linkages moved. I then promptly doused with PBlaster. Problem solved!
Doug
I tryed a good silicone oil spray, didn't help. What is PBlaster?
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2010 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2010 UNKNOWN 16...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
40ft 10-Door Shipping Container (A52377)
40ft 10-Door...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
