BX2230 54"mm (56Hrs) Lift Control Sticks
   / BX2230 54"mm (56Hrs) Lift Control Sticks #1
advanced24
Connecticut
BX2230
BX2230 54\"mm (56Hrs) Lift Control Sticks
Lift Control Sticks and doesn't return to center. I tried adjusting the rod nuts but still sticks. My Dealer said there is not much he can do and it may work its way in. I think if it hasn't worked in by now it never will..Any one else had this problem..
   / BX2230 54"mm (56Hrs) Lift Control Sticks #2
Re: BX2230 54\"mm (56Hrs) Lift Control Sticks
I had a similar problem with mine. I tilted up the seat and operated the lever to see what rods and linkages moved. I then promptly doused with PBlaster. Problem solved!
Doug
I tryed a good silicone oil spray, didn't help. What is PBlaster?
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
