BX2230 Front Axle Oil Change
   / BX2230 Front Axle Oil Change #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
First off, the manual says the capacity is 5 qts. They are full of it, 4.5 qts max since 5 qts fills it over the top. I drained and refilled with the precious Royal Purple 75W90. After I drained it to the correct level, here's where the question is. I run the tractor and then check the level and it sounds like a tire with a leak and hisses til the filler/dipstick is out.
Is this normal? Just seems odd to me.
   / BX2230 Front Axle Oil Change #2
Yes, it is the same as mine on both counts (capacity and venting.)
Will
   / BX2230 Front Axle Oil Change #3
I found that by adding a little suction to the top vent on the portal, you can pull some fluid into each knuckle.
By doing that, I was able to get a full 5 in mine, with a normal reading on the stick. I think with the thicker oil, it doesnt want to run into all the nooks and crannys of the portal axle ends.
Be carefull tho, they fill up fast! /forums/images/graemlins/tongue.gif
I have been making sure I vent the axle after each major use, should help keep the pressure down. Someday I suppose a vent will be added to avoid that. Your seals will thank you if you keep it vented!
   / BX2230 Front Axle Oil Change #5
A piece of hose, and my mouth! lol (works best with a LONG hose!) /forums/images/graemlins/blush.gif
I have this picture of me drinknig a few ounces of Royal Purple trying to do that. I know the gear oil is better for the tractor, but I can understand the use of the super thin UDT in the front axle.
   / BX2230 Front Axle Oil Change #7
Why is 80w90 better?? Under the circumstances udt would be just fine. Remember we are not talking about a ring and pinion in an automobile. The front axle turns at such a low rpm. Another example is to look at manual transmissions which use ATF fluid today and the operate at much higher rpm,heat,and stress. The only advantage here I see is maybe there is a lesser chance of fluid leaking by the seals. Also just remember what’s lubricating your HST gears.
just my two pennies /forums/images/graemlins/grin.gif
Probably no advantage but I like to have gear oil on gears. I'm a fan of Royal Purple so I use in about everything I own. Sorta like the Amsoil fan on the site.
   / BX2230 Front Axle Oil Change #9
I won't argue about synthetic oils. I love them two. I was using royal purple for the past two years in the lawn tactor and generator but have switch to mobile one do to price(was getting a great deal threw a local rep $42 for a case). I plan on using amsoil in the kubota. But for the front axle I will stick with super udt when it comes time to drain.
   / BX2230 Front Axle Oil Change #10
Don't forget to loosen the "drain plugs" on your front axle in the spring and drain any moisture out.
According to my service book you can use SAE80/90 in the front axle... This is the same oil the Ford 9N's use in their transmission/hydraulics. (and probably other tractors too). Since I have 5gal sitting around from using in my 9N... I plan to use that when the time comes to replace the oil in the front axle.
Super UDT is expensive.
-Dave
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
BELSHE DT-235 (A53843)
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
Honda EM3500S Generator (A55851)
Honda EM3500S...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
