BX2230 only runs in start position
   / BX2230 only runs in start position
Yes it is a stop solenoid but there is still fuel in the line that gets sucked in and lets the engine fire.
I have had this issue before. I would start with the easy trouble shooting first.
Its one of the fuses next to the battery, behind the ignition correct? In that case, all fuses are good
   / BX2230 only runs in start position #12
Ok, next loose or broken wires. You can ohm the solenoid to see if it is bad.
Looks like its the solenoid. After review, i see the back of the solenoid melted and popped.
   / BX2230 only runs in start position #15
The solenoid should not be melted, it is only energized when shutting down engine and then is released.
David
   / BX2230 only runs in start position #16
I had an issue with a "leaky" timer relay. It was sending a small amount of voltage to the stop solenoid all the time eventually causing the solenoid to freeze up. Ended up replacing both the relay and the solenoid to solve my shutdown problem.
2016 International ProStar T/A Sleeper Cab Truck Tractor (A51692)
2016 International...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
STORAGE FEES (A54313)
2018 Ford F-250 4x4 Pickup Truck (A51692)
2018 Ford F-250...
