BX2230, w/ 60" mmm Mower Review
   / BX2230, w/ 60" mmm Mower Review #1
proudestmonkey
Platinum Member
Cottage Grove, Minnesota
Kubota BX 2230
BX2230, w/ 60\" mmm Mower Review
I posted a lengthy initial review on the reviews page, with first impressions after 10 hours.
Last night, with just over 25 hours, I used the 2230 to mow for the first time. So, I thought I'd post a mini-review just about mowing.
Attaching the mower:
The mower was more difficult to attach than it needed to be. In order to get the beast under the tractor, I had to turn it because the front anti-scalp wheel hit the front tire with a straight-in roll. The PTO attachment scared me, so I checked it three times before lifting the mower. In actuality, it attached easily, the first time. To get the rear linkage connected, the rear anti-scalp wheels had to be almost touching the tractor's rear tires. When attaching the front linkage lift thing, it is necessary to first insert the right side (facing the front of the tractor) before the left. The manual said nothing about this.
After checking the height adjustment and linkage lengths (all was fine), I played with the height knob, only to realize for the first time that there appears to be no way to use the mower while having my rear ballast box attached (I use it for tools, not weight, when the FEL is off). When you lower the mower, the rear 3 pt hitch goes all the way down. I tried adjusting the lifting rod to raise the 3pt hitch lowest position, but found that if I adjusted it enough to avoid the box scraping the ground, both the 3pt hitch and mmm raised back to the top (to find "neutral" position). Ideas would be appreciated on this issue.
Mowing:
First thing: when I started to mow, I thought the cut was uneven (even though I carefully checked height adjustment of the blades and linkages right after attaching the mower). I then noticed that the throttle button kept sinking back from full throttle to probably about 2200 to 2500 rpms. I ended up holding it in full throttle most of the time. When I was finished, I removed the screen under the dash, found the nuts that hold the throttle bar, and tightened them, problem solved for next time.
The end of the shoot is hard, sharp metal, as I soon discovered by coming a little too close to an aspen and cutting its trunk. Bummer. I think I will try to figure out how to add a thin piece of plastic to the end to avoid this in the future. I have lots of trees and the 60" with shoot is very wide (about 6 feet across).
The suspended deck, with anti-scalp wheels, really did a great job of avoiding too much scalping. My JD had a rigid deck, and I scalped quite a bit, even at the heighest setting. I do wish, though, that it had a setting of 5 inches. This might seem like a lot to ask, but with my hills, rolls, and varying needs, something in between 4 inches and the top (about 6-7 inches cutting height) would be helpful.
I love how easy it is to raise the deck with the hydraulic lift lever. I can quickly go over my gravel driveway in between lawns w/0 turning off the deck--when in its top position, the blades do not suck up the gravel.
On the one hand, the large size of the deck is a bummer, because there are plenty of areas I can't get in between trees, or trees and a fence. My JD L130 had a 48" deck, so I could get places I can no longer mow with the Kubota. On the other hand, having a deck so much wider than the tractor allows me to mow under low-lying branches without running them over (too much). The other thing I noticed is that the cut is actually about 60 inches on this. My JD's 48 inch deck actually cut closer to 44 inches, so I am getting swaths nearly a foot and half larger. That is a big difference and should cut mowing time down considerably.
I also love how much more agile this tractor is than the JD. I can go up and down hills I would not even try with the JD, due to traction, and better ground clearance. I actually felt alot more stable as well. Speaking of which.... With liquid in the rear tires, a 250 lb. mmm, and the engine over the front wheels, gravity is really my friend on this. I only felt tipsy once, when trying to mow the edge of a flat part of the lawn that ends in a fairly steep hillside and I took the front wheel a little to far over, but then corrected it without incident.
As to the quality of the cut, its so-so. I think that will change when things are drier here, and when I mow with the throttle not trying to slip back to a lower rpm.
Mowing:
   / BX2230, w/ 60" mmm Mower Review #3
Re: BX2230, w/ 60\" mmm Mower Review
Thats a nice summary. I upgraded last fall from Sears mower to B1750 with MMM.
The Sears mower/tractor came with the property and I kept it running for 4 years with a welder and a lot of elbow grease. Our property is woods and pastures - like a microfarm - and the poor mower was never ment to be used/abused on anything like that.
Anyway, last year was a drought in VA and I didnt get much use of the MMM but this year I am very impressed. First it is fun to cut the grass, since I dont have to listen all the time for what breakes down. Second - Kubota is 20HP and sears was 23HP - but you could not tell. And no stupid belts to be smoked or burned. Third, Kubota will clear and cut and shread everything it bends down - like brush and small trees. And like you said - the hydraulics for lifitng is great.
Also cutttiing the ditch by the road with the mower was always a challlenge due to the slope - now it is not a big deal.
I wish I ditched the mower long time ago:)
   / BX2230, w/ 60" mmm Mower Review #4
   / BX2230, w/ 60" mmm Mower Review #5
I have no problem just sliding the deck under the tractor, I can fully attach it in about 3 minutes. If you contunue to have problems you can turn the front wheels slightly to give you more clearance when sliding it under the tractor. Now for your 3-point problem. You'll notice above your lift arms there are tabs on the frame that have holes in them, these are used to hold an implement in the "up" position. You simply raise the implement and support it underneath then pull the clips from the pins connecting the lift rods from the upper lift arm and pin the lift rods to these tabs. This will then "disconnect" your 3-point from your mower deck.
   / BX2230, w/ 60" mmm Mower Review #6
   / BX2230, w/ 60" mmm Mower Review #7
I'm guessing your opinion of the MMM will soften after you do it a few times. I notice you do have a FEL, I use mine to lift the front of the tractor up to slide the MMM in. Then lower it and remove later.
I also don't remember the manual saying to run the MMM at full throttle. I believe it said around 2500 rpm. Full throttle is over 3000 rpm. Your cable may have been loose but you might want to look at the book again to make sure I'm wrong.
   / BX2230, w/ 60" mmm Mower Review #8
   / BX2230, w/ 60" mmm Mower Review #9
/forums/images/graemlins/cool.gif
I did not know that. Thanks, Jrlichina!
   / BX2230, w/ 60" mmm Mower Review #10
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
