Valley Viking
The land pride 1248 box blade I use on my BX25D weighs 312 lbs. It is plenty of counter weight for this machine. I don't know why someone would spend money on a weight box.
I believe it's right at 1300lbs. The rest of the tractors I look at comparably are at 1800-2000 lbs. This is my one and final hang-up on buying this great tractor.
The weight is great from a mowing perspective, but I'm looking to do more. I've got some FEL issues with such a light weight. I won't be doing tons of FEL work but enough I've got to worry about it.
I think you're mistaken. The 22HP B-size tractors run ~1300 pounds. If memory serves, my BX2200 is speced at 1600 pounds w/o implements - I have to assume the BX2230 is the same. With a loader and mower deck, it's pushing 2000. Weight aside, it's pretty much worthless for FEL work - it's the little wheels, I think. I'm not running any extra weight on the 3pt - it would probably be better with another 500 pounds hanging off the back. It's also a little too heavy for mowing - mashes down the grass under the wheels and the deck doesn't have the suction to pull it back up so you get stripes. I recommend a B - I regret buying my "worst of all worlds compromise" BX instead of a B.
My local dealer sells the box blade for $599. I don't know what weight boxes cost but if I could pickup a used box blade or tiller for couple hundred more than a weight box I would. They weigh about the same, take up the same space, but obviously have more uses.
