BX23 Fuel Issue Help...
   / BX23 Fuel Issue Help... #1
tshep
Richmond, VA
BX23 MLB
Ok, was running just fine.
Tank got low.
Engine burbled once, I cut it off and went for fuel.
Got Kroger car fuel, no fuel buddy!
On restart (no burble), after a while (10 minutes?), lost high RPM power, hi rpm burbles, etc... got through the day.
Threw in Diesel 911 per NAPA recommendation, no better. Through the day affected lower RPMs. Got through the day, coming home tomorrow.
I have 1 Kubota fuel filter in hand - do I change first (pre lift pump) or second (pre pressure pump on engine).
First or second if only 1 in hand?
   / BX23 Fuel Issue Help... #2
Change the first one by the lift pump under the tractor.
   / BX23 Fuel Issue Help... #3
Also, when the tractor is KOEO, is there noise like a pump emminating from the bottom of the tractor where the lift pump is?
I do hear the pump, it was changed, oh, 150 hours ago.
   / BX23 Fuel Issue Help... #5
On principle, try bleeding the fuel system per the manual. It may not help but can't hurt.
Well, first filter seemed to do it, Messicks on the way, and no work days for 10 days or so... so probably solved!
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
