Bx23 in creek
   / Bx23 in creek #11
okay- I checked mine- no rotation of shaft ,no play. sounds like you got quite a few splines broken off the shaft. If this is the only damage you have, then you are lucky- just replace shaft, ujoint and call it a day. well- you also should be changin the oil in front axel. I dont recall a breather vent, but won't be surprised if there is one. The oranage dipstick/filler hole should be sealed with o ring- you should not be having a milky appearance to the front axel oil, if it is, drain it ASAP and refill with SUDT or gear oil. I prefer the SUDT to keep things simple.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2019 Harley Davidson (A50324)
2019 Harley...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
