gerford
Bronze Member
My BX23 is sick. I was back-hoeing a larger parking spot for a friend and when I went to use the FEL to move the dirt I loosened with the backhoe, the transmission wasn't up to the task. It was in 4 wheel low and as I went into the pile, the transmission would make a loud-kinda fluttering noise and have no power. I loaded a couple of buckets and the tractor would drive down the road fine, but when it needed to do some work, it didn't have the power it use to and makes a noise that says something is wrong. I checked fluid level and it was mid range and the implements work perfect.
The transmission works fine until I put it under a load and then the noise comes from somewhere under the seat. It would never be able to plow snow the way it is.
The machine has about 520 hours and just had its 500 hour service at the dealer about 20 hours ago.
I'm thinking I have to take it in to the dealer to get it fixed. I see there is a high pressure relief in the transmission and hopefully that might fix it. I saw in some other threads that a new transmission not a cheap fix.
Any ideas?
Any ideas?
