RStricker
I recently purchased a 2005 Kubota BX23. It's not received the best of care, and the electrical system has had lots of "field modifications". It appears that essentially all safety switches have been cut out of the loop.
When I first started using the tractor, it would intermittently stop. No rhyme or reason to the stopping, just randomly stop. It would almost always start up immediately, but I never knew when it would stop. I replaced the fuel filters and made sure the booster fuel pump was adequately tied in to the 12v power. Also, turning the key off would sometimes stop the engine, and sometimes not - this is why the previous owner had connected a link to the fuel shutoff lever on the side of the injector pump!
In my efforts at troubleshooting, I started trying to figure out the stop solenoid. My multi-meter said that at all times there was no power going to it. So i disconnected it electrically (I just unplugged the connector wires) - and all of a sudden my problem went away. The engine continues to run until I reach down and pull the link to the fuel shutoff lever!
I'd like to restore the tractor electrical functions to something close to the original factory design, but I really need to understand the function of the stop solenoid. I bought the factory service manual, but the couple of paragraphs related to the stop solenoid are not correct. The manual shows a 3-wire connection in the discussion of stop solenoid troubleshooting, whereas the electrical schematic, and my machine have only 2 wires. If the stop solenoid has no power going to it while the tractor is running, and certainly will have no power going to it while the key is off - then how on earth does this thing work?
This is enough to make my head hurt - I'd appreciate a clear and simple explanation of what's supposed to be happening here.
Thanks for your input!
Robert Stricker
Robert Stricker
