BX23 vs. B7800
   / BX23 vs. B7800 #1
MMH
Murrysville, PA
JD 4500
Beginning to look for a tractor. Just bought a house on six acres. Will have 300 ft. of gravel road to maintain. Will also be putting on an addition - will have to excavate about an area 25' x 35'. Also, will need to do some clearing to put some trails in the forest behind the property. Eventually use for some minor hobby farm work. Possibly put in a small pond? Who knows...
Was thinking that a B7800 was about the size I needed, but the BX23/24/25 seem to be much less expensive than a B7800 size machine. Will the smaller BX series do the job?
   / BX23 vs. B7800 #2
Beginning to look for a tractor. Just bought a house on six acres. Will have 300 ft. of gravel road to maintain. Will also be putting on an addition - will have to excavate about an area 25' x 35'. Also, will need to do some clearing to put some trails in the forest behind the property. Eventually use for some minor hobby farm work. vntually put in a small pond? Who knows...
A BX25 will not be cheaper than a B7800 discontinued tractor. Are you talking new or used? Are you talking a B7800 with a back hoe? I've had a B7800 and now have a BX25. These are not really comparable tractors. The BX23/24/25 has a BH and lower ground clearance if that's an issue. I use mine alot for moving rocks around and digging holes for trees and other holes. The B7800 with FEL will be a good around home tractor for moving stuff but without BH won't be much for digging holes. Maybe you were planning on getting it with a Back Hoe and if so it will dig a bit better than the BX25.
For major excavation work I'd recommend hiring some one with a machine made for excavating. It will do it in a few hours to your days or weeks. I actually have a man coming to do some work for me with a track machine. Some of what I need him to do I can't do, move car size rocks and part of what I'm having him do is really dangerous hillside clearing that he can do safely and in a couple of hours and would take me, with tightened spincter muscles, days to do. It's worth the $90 per hour to have him do it, safely and quickly.
I'm sure others will give their opinions but you need to clarify a few issues of the new or used and BH on both machines.
   / BX23 vs. B7800
Yes, I'm only considering used. Also, definately would get the backhoe w/ it.
   / BX23 vs. B7800 #4
B7800 is a much better choice for forest work due to the increased ground clearance and lack of transmission cooling fan. I may be biased since I own a B7800 - but have found it very good for a wide variety of jobs.
Mike
   / BX23 vs. B7800 #5
I just purchased a used B7500 with a FEL / Mower . I came very close to buying a BX , but I was concerned with ground clearance issues and lift capacity of the 3 point hitch .
After having the tractor for 1 week I am very Happy with my decision . With the FEL off the tractor it becomes a very maneuverable mowing machine and with the mower off and the FEL on it is a very versatile tractor . Both implements are well designed and fairly easy to take on and off .
Best of luck in your search .
   / BX23 vs. B7800 #6
If you look at a lot of tractors a 5HP increase is a huge jump. A 5HP increase will most times jump you to the next size larger tractor. 5 HP doesn't sound like much but in the world of tractors it sure seems to be.
   / BX23 vs. B7800 #7
Can't beat JOHNTHOMAS' advice he has had them all. I have several tractors, but sometimes, it is better to just pay a professional.
   / BX23 vs. B7800 #8
I'll just throw out my opinion.
Since you didn't mention mowing or wanting a MMM I'd consider jumping up a size and looking @ the L2800 and L3400.
I'm not sure where they compair on price for used units but given the tasks you listed, I think you'd be much better off.
Sure the tractors you mentioned will do the tasks you want, but the 2800/3400 is just a little better suited for those tasks and will get done a good bit faster IMO.
   / BX23 vs. B7800 #9
I agree!!! If you own a 16oz hammer (even if it's the nicest hammer on the planet) You don't use it to cut down trees. I thought I could do "real" excavating with a 45 horse Kubota until I gave up and hired someone with a Cat 963 - They literally did in 10 minutes pushing out stumps what would have taken me DAYS to do. This analogy seems stretched but it is not - A trackloader is hundreds of times faster on some jobs than a small tractor - That being said, try to mow your grass with a 963!
3084 (A46502)
3084 (A46502)
Wheel Adapter Plates (A49339)
Wheel Adapter...
2016 MACK CXU613 DAY CAB (A45678)
2016 MACK CXU613...
Skid Steer Trailer Hitch Plate (A46502)
Skid Steer Trailer...
Garage Door Panels (A49339)
Garage Door Panels...
John Deere 11.4in. Monitor (A46502)
John Deere 11.4in...
