BX2350: How Much Work Capacity?
   / BX2350: How Much Work Capacity? #12
gunpaq said:
~~~~~~~~~~~~Will the BX2350 actually perform or is it a glorified garden tractor?**************
I have a top of the line Cub Cadet Garden tractor and a Kubota BX 23 Sub Compact.
The CC is a great machine but believe me there is no comparison between it and the BX23.
The difference is so great between a garden tractor and a BX that I just recently bought a BX1500 to replace the Cub Cadet and a second BX1500 to mow around the house with.
Just like I underestimated the BX23 when it bought so did I with the BX 1500s as they also never cease to amaze me to.
   / BX2350: How Much Work Capacity? #13
If you cruise up to a stump and expect to pop it out like you would with a 60,000# CAT Excavator, you'll be pretty disappointed.
If your only frame of reference is the biggest Crapsman made, you will be VERY pleased with the amount of work this series of machine is capable of...considering it could DEAD LIFT and carry the biggest Crapsman made...
I have put a measured 640# (of softener salt) in my FEL and carried it around the yard without any problem. Note that the loader is 'officially' rated to just over 500#.
   / BX2350: How Much Work Capacity? #14
The BX is perfect for your apps. Especially considering that you have other larger machines. The biggest advantage of the BX in comparison to the L, M and even the B-series machines is it's manuverability. For that reason I wouldn't recommend the B unless you didn't already have the other larger machines. It's capabilities are the same, just scaled proportionately. I use a BX1500 for several of the same or similar tasks you mentioned.
   / BX2350: How Much Work Capacity? #15
What shocked me was to realize within a week of getting my 2 BX1500 tractors that I could have done everything with a BX 1500 I'd done with the BX23 except the Back hoe jobs.
Would you trade your BX1500 for a JD x729,x749 or other JDx700 series?
   / BX2350: How Much Work Capacity? #16
Reading the OP again, I am absolutely in agreement that the BX would be the way to go. It will be much more capable than you imagine. It is VERY maneuverable and you won't run out of finding things to do with it anytime soon.
   / BX2350: How Much Work Capacity? #17
gunpaq said:
BX2350 Work Capacity?
How much heavy duty type work is the bx2350 capable of doing with a FEL, etc.?
Looking at one for our farm to do the lawn mowing, manure clearing from the small stables, rototilling, move feed bags and loose feed, snow removal/plowing, and running small bush hog type mower for around the fences and so on.
We run a full size cattle farm and have the other Kubota M & L series tractors for doing field work.
The local dealership salesman says the BX2350 will do most anything.
What is your experience?
Thank you.
Hi I bought my BX24 in november-07, till today Ive done 100hours, mostly construction works for clients. I bought (in US) the bx not have seen in real life because I live on the other side of the globe....First when I saw it I got scared...Man that was a very small tractor:eek: BUT now after 100hours of hard work Im impressed...REALLY impressed, as many guys say and I agree, it wont lift to heavy loads on the FEL, but it lifts alot compared to its size. Sometimes you forget that u are using a small tractor so u go wild and try to lift stuff it aint made for...;)
I would recomend the BX for U
/Sam
Case IH 2388 Combine (A50514)
Case IH 2388...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2006 Poly-Coat Tanker Trailer (A50774)
2006 Poly-Coat...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
