BX2350 parts falling off!
   / BX2350 parts falling off! #1
robbo323
Central NY
Kubota BX2350
BX2350 just hit 50 hours. Looked under the hood today & surprised to find all 3 bolts supposed to be holding cooling system reservoir tank on had all vibrated loose & disappeared. Worse yet, plastic reservoir then apparently leaned forward enough to rest up against belt pulley and ground a hole nearly through the reservoir! Anyone else have this happen and is it fixable under warranty? For the short term, anyone have any idea what size bolts I need to get this back on to limp by until I can get a hold of the dealer? I have a parts book that says they're #01754-50612, but no size.
   / BX2350 parts falling off! #2
It better be fixed under warranty....no excuse for that one. Not sure on the thread size, but the first thing is identify if it is fine or coarse thread....this is the spacing between the threads themselves.
The other thing is find some soft material like play-doh, and take and impression and match it up at the home improvement store. Length you should be able to eyeball. HTH.
   / BX2350 parts falling off! #3
Went out and checked mine. Everything appears to be tight. First I've heard of this one...hopefully just a fluke. Personally, I'd just go down to the hardware store and get replacements, give the receipt to the dealer...can't be more than a couple bucks. The reservoir on the other hand...I'd have the dealer give you a replacement...
   / BX2350 parts falling off! #4
Those bolts are likely to be 10mm metric with a flanged head. Look around your tractor to find what looks like the same size and try it for fit. If you find one you will have something to match to.
Vernon
STORAGE FEES (A52577)
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2017 Freightliner M2 106 24ft Box Truck (A50323)
2017 Freightliner...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
