Buying Advice BX23S options question
   / BX23S options question #11
The difference in loader lift and breakout are in the literature... probably as JohnThomas has noted above. To me, the BX is a handy unit, that even reducing its capacities by 80-90 pounds is real loss. That's why I like Jery's QA and forks. Also, the center hook that aligns the QA on the implement is great for hooking up on uneven terrain. If it were a B-series or other, which needs both outboard pins to attach, it might be different, but Jery's again, hooks the top pins and latches on the bottom pins. Then, add the 2" receiver.
Back to the weight differences, the SSQA plate and levers weight are more likely the difference in the OEM KUBOTA QA and SSQA. Jery's QA is heavy, but built tough with more steel than the Bota QA.
Can anyone tell me what SSQA attachments would be useful on the front of a BX? Again, unless there is some sort of secondary self-contained hydro unit running of the rear PTO, I can see a BX providing enough hydraulic pressure or volume for a sweeper, post hole digger, front backhoe, etc.
   / BX23S options question #12
I saw that there is finally a full brochure with the info for the 80 series Still doesn't answer the question about how the other qa, both the kubota pin on qa and the aftermarket options compare.
I hear a lot of people say the ssqa kills too much lift capacity compared to the other options but haven't seen the numbers for the other options.
Personally ssqa isn't my favorite system but I like it better than the pin style qa.
I just went to the dealer today to look at the Bx23s and they only stock the qa. I guess it is about a $300 option that the dealer assumes most will want. Based on my needs, I don't think I am going to notice the difference between the qa vs. pin on as far as lift capacity is concerned. I am ready to sign the paperwork but I have 2 more questions. The first is regarding which mower to get for hilly terrain. I am just trying to knock down the native weeds on about 3 acres (about 45 minutes from Yosemite, oaks, pines and poison oak... lol). I was quoted pricing on a rotary mower but am wondering if a mmm would be better? The second question is if Kubota makes a third valve kit or if I should go with the land pride kit as I am wanting a grapple. The dealer believes that land pride is the only option but I swear I saw that Kubota makes a kit now? Not a big deal either way but I am partial to the factory stuff if possible. Thanks again for all of your help!!
   / BX23S options question #14
Kubota makes a kit, but it COSTS. I'm putting on the dual rear outlets for cheaper cost. It offers four outlets (2 in-2 out). I can use them for positions with a blade that I'll use less, like tilt and curl. With a grapple, if you can reach down to the fender, you can do the same with the rear outlets.
I think the third valve from Kubota was like $800, Land Pride about the same (think LP makes Kubota's, like many of their implements. The rear dual by Kubota is like $400 with TWO sets of valves.
   / BX23S options question #15
If you're doing a lot of grapple work the 3rd function on the joystick makes life a lot easier, for occasional use I'm sure the rear remotes would be fine to operate the grapple. I have a diverter valve setup on my B and I prefer it for its efficiency, but I use my grapple a lot.
hmmmm... a lot to think about! I was quoted the land pride 3rd function kit but since I have not signed the contract so I still have some time to change things. I guess I will be doing some more research this weekend. Is the 3rd function kit something the dealer should be able to handle pretty easily? (I think the dealer is a fairly large dealer, the had (2) bx23s in front of the sales office and over 100 other tractors in the yard). I assume they have done this before?!?!
   / BX23S options question #17
You could install the 3rd valve or rear remotes if you have some mechanical aptitude.
   / BX23S options question #18
RobertM - would like to see more on those rear remotes you mentioned for the BX. I have a BX25 and I'm fairly certain I read somewhere that Kubota doesn't have a kit for the BX25. Hope I'm wrong as I would like to add TNT. (Also - really appreciate all the info on the tach-n-go, gonna get his set up soon!)
Anyone seen a post where someone did dual rear remotes on a BX24/25/25D? Thanks!
   / BX23S options question #19
Add the shim kit to the pump and the QA loader will do anything that the PIN style loader will do. Just keep the pressure just under 2000psi.
Grasshopper 721 Zero Turn Mower (A59814)
Grasshopper 721...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner 122SD T/A Day Cab Truck Tractor (A60460)
2015 Freightliner...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
Tanker Trailer (A59230)
Tanker Trailer...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
