Snow BX25 3pt snow blower mounting trouble
   / BX25 3pt snow blower mounting trouble #1
bxn
Hi
I am have a bx25 with a 3pt hitch kit and 51" snow blower that I am trying to mount on it.
Once I picked the blower off the skid with the 3pt hitch it would not go down all the way to the ground (flat garage floor). It appears that the (non adjustable) lift link is binding between the upper lift arm and lower arm. It is not able to descend. I asked the dealer about this and they showed me another kit with exactly the same angles on this lift link. They suggested that my check chains were too tight so I loosened these but it still won't go down.
Does anyone have a bx25 with 3pt mounted snow blower with pics I could look at? I would like to know what I am doing wrong here.
The other item I am interested in is which hole is used on the blower for the lower arm pins.
bxn
Never mind. I moved the lower arm hitch pins on the blower to the upper holes and problem solved.
Hope the solution is useful to someone else.
bxn
   / BX25 3pt snow blower mounting trouble #3
that is good to know and welcome to tbn
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
TRAILER AXLE (A51244)
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2001 Sterling Vac Truck (A50323)
2001 Sterling Vac...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
