Rock Crawler
Veteran Member
- Joined
- Aug 15, 2017
- Messages
- 2,227
- Location
- Pittsburgh, Pa.
- Tractor
- 2021 Kubota L3560 HSTC, 2011 Craftsman Excellerator GT (680hrs), 2018 Husqvarna TS354XD, 2017 Husqvarna HU800AWD, 2019 Kawasaki Mule Pro DX (Yanmar)
My BX25 does primary duty as a dirt digger/mover and when I bought it (used) a month back I had the tires filled with Rim Guard immediately. I run the recommended 18PSI front and 22PSI rear pressure. I was noticing at first that the wheels would chatter and slip/catch/slip in the wheel causing the chattering. After another couple weeks I noticed that instead of spinning tires as I was pushing into a hillside with the loader, the tire(s) would stop moving. At first I thought the axle HST unit was dying, until I leaned over and saw that the wheel was gleefully spinning in the motionless tire. I also noted a shiny damp glaze of rim guard around the wheel/tire interface.
So this past Sunday I removed the back wheels and tires and took them to be pumped out, cleaned, tubes installed and the rim guard pumped back into the tubes. I hope like **** that this solves the issue!
I'm guessing that this is not a normally seen thing, but I suspect the reason the little BX has the issue for me is that the 12" diameter wheel does not near the bead surface area of say a B or L series unit. I suspect that the little wheels with less surface area to grip on could not take the forces while having a fluid trying to lubricate the interface.
I'll let you all know if the slipping rim returns. The bad part is that if they slip now, they will tear the valve stem from the tube and really screw me good and proper. I really did not want tubes, but I see no other solution.
