Buying Advice BX2660 Going to be too small?
   / BX2660 Going to be too small? #11
Thanks for the replies. Some more info...
The ground is wide open field with some slopes but nothing crazy steep. I already have a loader, 54" underbelly and rear 48" blower for the white stuff. the future driveway is marked out and is 350' long, 10' wide.
I will have quite a bit of grading and re-grading to do on the property after the house, driveway build and geothermal trenching so a box blade and landscape rake are most likely in the cards (as well as a rear hydraulic remote based on what I have been reading to make it much easier to use the box blade).
The entire property is 12 acres with 90% field. I won't be mowing all of it but for sure it will be a solid half being mowed. The boys want a place to play soccer so the field where the geothermal piping will be installed will most likely be re-graded to reduce the slope somewhat. Had some lengthy chats with the local dealer and of course they want me to upgrade but at the end of the day, I would be spending 7 - 10k more for a larger machine and would have to change out my implements for larger models. I am leaning hard towards a used zero turn 60" to add to the stable ($3-4k),.... or a used 2wd tractor with a rear 72" finish mower (under $7k). With the boys helping out, it would make things a lot quicker. Can you really have too many tractors?! :)
I suppose in theory you can, but in real life, I'm not so sure.:laughing:
For a lot of years, I used a lawn mower and Ford NAA with 84" RFM to keep our place mowed. If you can find a good used 2WD tractor, you can do a lot of work in addition to mowing. My brother does all of his box blade work with a Ford 600. Massey Fergusons are really good reasonably priced older tractors.
There are a lot of guys with more expertise on here who can help with your selection if you go that route.
2006 FORD F-250 (A52472)
2006 FORD F-250...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
48 PIECE HEAVYEQUIPMENT KEY SETS (A52472)
48 PIECE...
